Just been down to plumbers merchants and got some pan connectors, etc.
Tried fitting the striaght connector on and it just pops straight off again!!
The connectors are for 110mm as usual.
The outlet on the WC is tapered but starts at ~ 104mm so shouldn't be any problems there, it is however glazed, should I scuff it up a bit to allow the connector grip?
It's a tight fit so I used fairy which allows me to get it on, but then it just pops off after a few seconds!!
