Can't help at all on the warm air fault, I'm not warm air qualified and only ever seen one when I take them out![]()
The Alpha though, you say it is definately the fan but then seem to doubt your appraisal of the situation.
Have you checked if there is 240V at the fan terminals? If there is it will be the fan. If there isn't the fault lies elsewhere.
Have you got the MI's for the Alpha and gone through the fault finding precisely?
Unfortunately there is no substitute for experience and I'm sure all of us at some point (I still do very occasionaly) buy a part that we have wrongly diagnosed as faulty and end up having to put it in the van and hope for the day we can use it to get our money back![]()
Welcome to the real 'uncertain at times' world of boiler repairs.
Your confidence will naturally improve, take your time and slowly test everything and whilst learning make sure you only charge for the actual part and time it takes to repair the fault.
Wasted time and expense is a pain, but just put this cost down to learning. It will get less. Also revel in the delight of fixing each boiler you come across, especially the awkward ones, as this feeling will soon disappear into everyday drudgery of work![]()
Thanks for your advise and tomorrow i will now check the terminals as suggested.
My spares place has no problem with me connecting the fan to the boiler prior to fitting to see if this works also, so i shall try that as well!!
Your positive feedback has been gratefully received!!
