For your information. We recently had a Eco 32 warm air system installed to replace an old Halstead warm air system, all ok but one important item of note, in Feb 2011 we had some cold nights and our lounge was recorded at 24 degrees which is fine, the 2 ducts that go upstairs serve the landing to enable the air to filter over the 4 bedrooms - we were told the temperature will not be as good as the lounge where the heater is based - but the temperature in all 4 bedrooms was 14 degrees, the thermometers was hanging from the lamp shade which are in the middle of the rooms, so i asked Johnson and Starley and eventually got an answer, the upstairs temperature should be taken at the ducts which is slighty warmer than 14 degrees, so thats great, if we were told it would be this much of a difference we would not buy the system.
My conclusion is on cold nights sleep on the landing.
The system is fine if you have a bungalow, you start pushing air upstairs through ducts - and how long they are - the air push starts to deminish which is why our upstairs temperature was 14 degrees against 24 in the lounge.
Not happy with the product, it does not do what we were told, in fact the old Halstead was much better with the warmth, if you have the money buy a second heater for the upstairs but then cost ?, go for radiators.
Johnson and Starley have not done any customer care progress to see what else they could do, they have our money - via a contractor - and that's the end of it
