Help with connecting new light please (with pics)
16 Sep 2004
Leeds
Hi
Just moved house, as always the previous occupants replaced all light fittings with cheap white plastic ones, in this case a pendant. Bought a new fitting and removed the old pendant. Trouble is, 4 cables come in, so it has 4 neutrals, 4 live and 4 earths (one of the neutrals looks like a switched live).
How do I wire up the new light please.
Current wiring below
New fitting connector below
I tried putting the switch live (with red sleave) into the L of the new fitting, the single neutral into the N and put the earth into the earth. This resulted in the light working, but the hall and 1 other bedroom not!
Would appreciate any help on this.
Thank you
Black wire with red sleeving (switched live) into L.
Remaining blacks (Neutrals) into N.
Reds together in a connector on their own (looks like there might be a spare connector on the light block)
Green/yellows (earths) to Earth (the funny symbol between L and N)
As there are so many wires ensure that they are all terminated properly. :wink:
Reds together in a connector on there own (looks like there might be a spare connector on the light block)
Thank you very much. May need to change to the block to a bigger one to get all the wires in. Thanks again.
Thanks again. Bought a strip of 30A connector blocks which had the room to fit all the cables.
Thanks for the advice
30A is a bit big!
Make sure all conductors are secure - sometimes in an oversized connector they ride up next to the screw not under it & don't get trapped effectively.
