Help with fixings for heavy painting
30 May 2016
I have a large glass painting (the glass is the medium on which the painting has been done) in a wooden frame, that weighs about 25kg. It has a large wire on the back, so would require two screws/hooks at either side to hang it on.
I'd like to hang it on a wall in my living room. The wall is the external wall of the house, so behind the studded wall, is brick.
What fixings would you guys recommend, that would guarantee the painting isn't going to fall off and shatter!?
I thought I could use something like these heavy duty wall plugs hammered a little way into the brick behind the wall ( http://www.screwfix.com/p/rawlplug-fx-nylon-wall-plugs-5-x-50mm-100-pack/4485g ) but I'm having difficulty finding the correct diameter thread hook screws for them?
The alternative is maybe something like these hook screw anchor bolts ( http://www.ebay.co.uk/itm/M10-Threa...243848?hash=item54310dd888:g:xrwAAOSwvg9XY9Go ) - though I'm not quite sure how anchor bolts work?
Any suggestions?
Are there conveniently-located wooden studs? If you can drill into those it is easy.
I'm not confident that there is a stud behind behind where both screws would go. Maybe one could go into a stud, but the other would be between studs. We installed a TV bracket (65 inch TV) on the opposite wall, and ended up using the above rawl plugs hammered into the brick a bit for extra support, that has worked perfectly.
However, we used appropriate sized screws for that, but I need something on the head of the screw to hang the wires onto - so I think a hook is going to be the best option, but can't seem to find hook screws big enough?
Yeah I may just have to use a long screw with a washer pushed up towards the head, to give more space for the wires to sit against. Thanks for your help.
YOu can get quite long vine eyes, e.g. 150mm. They could be modified into hooks.
Vine eyes and screw hooks are available in quite big sizes. I think the ones I use are 75mm (3 inch) shaft.
They are used for supporting climbing or rambling plants, which can be quite heavy when loaded with fruit. Ebay is a good source but some gardening places have a small range.
edit
too slow!
View media item 97955
