I am wondering if the OP has also taken on board the advice from the manufacturers about where to fit the alarms in order that they are effective in detecting smoke. Fitted in the wrong place and they will not react until several minute later than they would have done if fitted in the right place.
And a reason for ensuring the CPC is continous and connected to earth at the consumer unit is primarily safety but also un-connected length of CPC in alarm wiring have been considered as the cause of false triggering. They can, if not earthed, act in a similar way (in lay man's term ) to an aerial picking up electrical noise in one area and taking it to the sensitive alarm in a different area.
