I hope you can help.
After removing and old toilet (old fashioned high up cistern) and the surrounding walls
that went into the utility room I was left with a 110mm soil pipe which runs parallel to the wall,
in a horizontal position - the problem is, this pipe is 50mm 'proud' of this wall.
i.e. the distance from the nearest edge of the soil pipe to the wall is 50mm.
This soil pipe (which I think is solvent weld) comes in from a wall on a 45 degree horizontal,
and runs for 300mm.
I have a new regular Heritage make, close coupled WC.
The distance from the 'open end' of the WC spigot to the wall is 90mm
The distance from the wall to the far side of the soil pipe is 150mm.
MY PROBLEM
The pan connector does not reach the soil pipe.
It would connect if I put the pan connector on the spigot by a "Nat's Whisker".
That is how much it is out, so basically if I pushed the pan connector 'fully home'
the pan connector would be 40-50mm to far forward from the wall.
I have tried various soil bends (well everything at B & Q) and nothing comes close.
I did find the Grey 110mm 0-90Deg Adjustable Bend, but try as I may, I could not
get it so swivel.
It did have printed on it all different angles - so I'm not sure if this was for cutting to shape.
In hindsight I don't think this will work either.
It is not the angle I have a problem with, but the short distance.
I have read not to use flexible pan connectors - if it turns out I cannot get these to marry - will I
be heading for lots of problems if I use flexible?
Just one other point.
I think this 110mm GREY pipe is solvent weld as the "Ring Seal" section does not seem as chunky
BUT I inserted a finned end cap which hasn't caused any problems - would this end cap
of worked if it was solvent weld?
I ask because I know that 32mm & 40mm solvent weld do not push in to push fit fittings.
I would appreciate any help because I have got 7 days left to get this toilet working before the
wife has an operation and will not be able to go upstairs (this toilet is on the ground floor).
Many thanks in advance.
