edit , not laughing at you op
edit again , op ignore that one
I understand that, and I'm very tempted. But what would they do differently to what has been suggested here?Easiest solution being to employ a proffesional..
The way you're proposing to install this machine the end result being blockages and smells.
edit again , op ignore that oneyour last query
The extension idea definitely seems the easiest. And it would save all this hassle of merging waste pipes or installing new things. I was hoping some one could confirm whether the length of the waste hose would be an issue so I know whether to rule out that idea or not
That's not what I suggested.Two washing machine waste hoses won't insert into a 40mm standpipe..If using a T to split the water supply then ensure whatever you use is full bore (some have a reduced size bore), if the washing machine outlet goes inside an upstand pipe (white plastic 32mm) then consider upgrading this to 40mm as far as you can then just drop both outlets inside the upstand, wouldn`t join them together in case of any backwash from one to the other.
Each machine should utilise its own stand pipe....industry gone to the dogs..
Two usernames????..Lavo/Just pumps...That's not what I suggested.Two washing machine waste hoses won't insert into a 40mm standpipe..If using a T to split the water supply then ensure whatever you use is full bore (some have a reduced size bore), if the washing machine outlet goes inside an upstand pipe (white plastic 32mm) then consider upgrading this to 40mm as far as you can then just drop both outlets inside the upstand, wouldn`t join them together in case of any backwash from one to the other.
You can use one stand pipe with u-bend/air break, but with a Tee (side on = |J ) thus two 40mm pipe sections for your outlets to hook in to. This way no restrictions are created to the waste water.
Three meter run for your waste extension will be too long in my opinion and I would look for another way of plumbing it.
