Hi. I wonder if somebody can help us.
The light switches in our living room are strange. They have always been this way since we moved in a couple of years ago and I'm thinking somebody has simply wired up one of the switches wrong.
The room has two lights, one either side, with a corresponding switch on either side of the room.
The light on the RHS of the room only comes on if *both* switches are in the on position. The light on the LHS of the room is constantly on, and therefore doesn't have a bulb fitted because we can't turn it off.
I switched off the mains at the circuit breaker, and pulled off the faceplate from the LHS switch to have a look if there was some weird and wonderful complicated wiring going on behind there. All I found was that the switch has three wires, all red, and appears to be a two-way switch with L1, L2 and Common connections.
Does it sound as though somebody has put a two-way switch in where there should be a one-way switch (although there are three wires)?, or is it more likely that the switch is switching the common instead of the L1/L2 or something?
I am not building-electrical savvy and have no knowledge of how these things should be wired (L1, L2 etc. ?) but should have no problems following instructions if anybody could be kind enough to offer some advice.
thanks for your time.
regards,
Carl
regards,
Carl
