HEP2O spigot elbow
22 Jul 2008
Yorkshire
Hi All,
I am fitting a shower and the supply to the mixer valve has compression fittings. I amusing HEP2O pipe in the wall then they need to turn through 90 degrees into the compression fittings. HEP2O sell a "Spigot Elbow" (http://www.discountedheating.co.uk/shop/acatalog/Hep20_White_HD4_Single_Socket_90_Degree_15mm_x_10mm_Street_Elbow.html) is this what I should use to achieve this? I could use a normal elbow and a short piece of pipe and insert but this would be a little messy I would guess. Any advice would be be gratefully received.
Many Thanks
