HETAS certificate null and void?
27 Sep 2011
Somerset
Since a disgraceful install by a registered HETAS bloke in May 2023, it was condemned by a HETAS inspector before even being used. Its been a long running battle ever since.
Is the HETAS certificate null and void? I have not been informed that it is, but it was mentioned to me recently that it could be.
If you take the last inspector at his word then surely the certificate is irrelevant, it needs recertification before use?
Is the system as installed compliant with relevant regulations and safe to use? If not (and you clearly have been made aware that it is not) then the only use for your certificate is as evidence in any civil or criminal proceedings.
Thanks for the replies. HETAS were ready to close the complaint as 'unable to assist' due to the installer not being very co operative. That would leave me without a working appliance through no fault of my own and if that is the case, I can't see how the certificate is worth much in the first place. The notification has been lodged with BC and that seems to be the relevant part.
What exactly is the problem that the HETAS inspector is flagging?
No CO monitor fitted or provided by fitter.
No attempt to seal at stove collar.
No attempt to seal at flue liner
No commission paperwork( because it wasn't commissioned)
Combustible substrate too close to appliance.
No smoke test.
Stove pipe not secured.
No smoke test.
Write a constructive polite email to the installer stating you will be getting remedial work done and then taking them to the small claims court for the extra costs
In fact, the cheeky git eventually provided an invoice that he had hiked by £200 and said he would not pursue the money I 'owed' it if I dropped my claim. Of course, I told him to go forth.
