    Dismiss Notice
Hi, Can I fit a 500mms door for a slimline dishwasher that is 450mm
Discussion in 'Appliances' started by Julie101B, 21 Sep 2020.
  1. Julie101B
    Julie101B
    21 Sep 2020
    2
    Thanks Received:
    Country:
    I am fitting a kitchen on a budget and the cabinet range doesn't have a 450mms door for the appliance I want, Can I fit a 500mm? There is room for 500mms but would the appliance be ok with more weight?
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    66,724
    Thanks Received:
    3,643
    Coastal
    Country:
    Cook Islands
    it might be possible to adjust the door spring, but you had better consult the installation instructions for the model you have in mind.
    • Thanks Thanks x 1
  4. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,605
    Thanks Received:
    566
    Country:
    I have
    What I did was to get some white contiboard style stuff and cut 25mm strips the same height as the units
    I then screwed this to each unit from inside the neighbouring cupboard, top and bottom.
    I also replicated the top rail of a unit.
    Then after a fair bit of wiggling, screwed the washer into the 25mm strip.
    It's a bit of a faff but works.
    • Thanks Thanks x 1
  5. JohnD
    JohnD
    15 Nov 2005
    66,724
    Thanks Received:
    3,643
    Coastal
    Country:
    Cook Islands
    Are you talking about fitting a door?
    or an integrated appliance?
  6. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,605
    Thanks Received:
    566
    Country:
    Sorry- I assumed it was an integrated appliance he was fitting.
    I read it that he could get 500 doors, but not 450's
    I was fitting an integrated 450 into a 500 slot
  7. Julie101B
    Julie101B
    21 Sep 2020
    2
    Thanks Received:
    Country:
    Hi, Yes I'm fitting an integral slimline dishwasher (450mm ) but I can make room for a 500mms door so that will mean the the door will oversized by 25mms each side , would it be possible?
  8. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,605
    Thanks Received:
    566
    Country:
    As above- I made 25mm infill strips
    • Thanks Thanks x 1
  9. Sponsored Links
Loading...
Share This Page
