Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
38Kw needs 3.55 M3/hour, 3.6M3/hour will go through 22mm pipe over 15meters, so am I missing something, if he isn't connecting anything else to this equivalent run of 13.5 meters, it's a 0.9mb drop which should be fine.
Take some advice mate stay away from the 838 exclusive they r as rare as hens teeth an have a low voltage pump which is not reliable go for the 837 ecotec tried an trusted bin out 5 years now an all problems associated with new units all sorted 5 years warranty if u get an improved installer an cheaper to buy! A no brainer mate
There will be a hob aswell so I cannot put it on the 13.5m run. Looks like you agree with calcs though which is good. I have seen nothing from landyandy which proves it will not.
I am going to a lot of trouble as I am somewhat anal. The house is rendered cream and all the waste pipes are white. I want it to match. I know it sounds like a lot of trouble - but my house is my hobby so extra effort is not a problem.
I will look at the 837 - you have put we off the 838 - what about a WB 42CDi?
Thanks for all the advice so far - very much appreciated.
Think you`ll find it`ll need to be painted yellow - with a black band at the end near where it goes through the wall to the boiler - make sure it`s not upright - use some old iron spiked hooks to hold it to the wall - and remove half a brick where it goes through - so that everyone Knows it`s a gas fitter`s done it
I haven`t a clue M8 I was just referring to the yellow covering on the iron pipe that they tend to strip off @ the ends - and the quality of workmanship as usually seen
