Hiding / covering stains in laminate flooring
6 Dec 2006
London
Some water worked its way into the crack between two panels of laminate flooring which led to some mildew forming UNDER the clear top layer of the laminate material (and in the crack itself) which is now visible in the "grain" of the material.
Rather than replace the flooring, I'm wondering if there are any "cover up" products which might be used to obscure the problem. Its a normal tan/beige faux-wood colour floor.
Since the water source has been removed (a potted plant) the mildew is not continuing to spread and the floor is not warped or otherwise damaged.
