Hiding these pipes
27 Jun 2009
Nottinghamshire
I am confident with radiator pies, soldering joints and fitting radiators. I currently have pipework that runs along the skirting board that I'd quite like to burry and bring up to radiator to make a neater tidier job of one that I have fitted in a dining room.
Do you think it'll be possible to get them down into the floor in this limited space:
Or do you think it'll be impossible to do? Are there alternatives to cutting a pipe other than a pipe slice or is it then impossible to put a fitting on the end if it is cut another way?
If I manage to get them down into the floor how would you suggest running them in the floor? I will need about 1 metre for one and 30cm for the other. The final finish is going to be engineered wood laid on insulated underlay.
Thanks for your help.
