Hi All,
Recently had a loft conversion done. 2 bedrooms and a bathroom. One large radiator in one room, bathroom has a towel radiator & the other room has one large radiator & a small one on the opposite wall. I obviously expected it would take a bit of time to get rid of the air after a bleeding the radiators over a couple of weeks & a few glugs and rattles from the radiators when in use is to be expected. There's also an auto air vent fitted at the end of the pipework after the last radiator.
The problem is that an hour or so after the heating goes off i get a high pitched whine that rises and falls and seems to resonate to the small radiator. I've adjusted the lockshields a little bit not that the radiators need balancing they are all so hot you could cook steak on them within minutes & I mean ferociously hot above setting number 2.
The whine goes on all night hour after hour its that bad you cant sleep in the room. The sound rises and falls about 6-8 times a minute so at night you can imagine 8 hours of it. jeez
I think its trapped air but i thought I'd ask around to see if there's any way of resolving it as the plumber seems to not have a clue.
I've left the heating on for 3-4 hrs to see if that purges it. ( the rooms are desert hot in 20 mins)
Your help is appreciated.
Oil fired central heating system. heating system is vented. standard s plan down stairs and added an extra 2 port valve to operate heating upstairs.
