Hitachi TV 22LD4200UK +XP
15 Jun 2004
Norwich
This could be a software problem. (I hope it is).
I have been running Windows millennium, using an Hitachi TV as the monitor, without any problems for 6 months.
I have today obtained a new pc running windows xp.
The system boots up, displays the XP logo, then I get a blank screen.( I then get an error message which is generated from the tv 'signal out of range') According to the tv user instructions 'PC input signal is not supported by LCD-TFT TV.
If I plug a standard CRT monitor into PC, all is ok.
Any ideas appreciated.
You probably need to boot into safe mode, and reduce the refresh rate to say 60Hz, LCD's do not really suffer from flicker.
Eddie...Just checked it ..it is set to 60..
I then reconnected to TV & ran in Safe Mode & its visible, but do a restart & get the same error message.
It took a long time changing from CRT to LCD, I got there eventually. It was a resolution issue.
