- Joined
- 10 Oct 2018
- Messages
- 3
- Reaction score
- 0
- Country
Hi All,
I setup Hive 2 a while back for downstairs heating and hot water and it works perfectly. This meant that my upstairs rads were still controlled by a danfoss tp5000 programmable room thermostat in the bedroom. Ive been out and bought the multizone kit for hive with the plan to replace the danfoss. I realise the danfoss is battery powered so i cant replace it directly with the hive control unit. Ive managed to wire the hive control unit into the wiring centre so ive got power going to it which is a great start.
My problem: There are 2 wires at the danfoss tp5000 a brown connected to COM and a brown/sleeve connected to NO Theres also a grey which is not blanked off by a piece of temrinal connector (i think!). I presumed that i'd be able to trace these back to the wiring centre - disconnect them and connect them instead to the COM and NO on the Hive unit (pins 1 + 3) to switch the heating for upstairs - this doesnt seem to work though - any ideas? Can provide pics if required
