Hi I have recently wired up a Hive receiver and is all working fine. However, my boiler is being fed from the fused switch via the Hive so I have twice as many cables (live, neutral and earth from the switch, and neutral, common, heating on and earth from the boiler as well as the link between common and live). I have been told elsewhere on this forum that it is common practice but this makes it very hard to push the receiver front onto the backplate nicely and is not quite flush on one side. It is secure and not going anywhere but would like it to be fitted properly. I can’t cut the cables any shorter than they are.
It says in the manual that I do not need the Hive to be earthed so potentially I could lose a couple of cables but my question is if the Hive is supplying power to the boiler, would I still need it to be earthed in any way? If I removed the earths, then the boiler itself would not be earthed which surely can’t be right?
Any advice appreciated.
