The BG guy deffo said its a live and neutral not live and live switched and that's why he couldn't fit it.
If he said that it's incorrect....However; if he said that he couldn't fit the Hive there because there 'isn't a live and neutral present' that would be correct.
The LP522 was fitted by our boiler people when the old one failed I think he didn't have a single one on his van
A bit unprofessional! (not BG again!
) But if that's the case and the LP522 only has water control connected to it, then unfortunately the wiring for the LP522 and CM907 thermostat will need consolidating and bringing together at the Hive receiver.
The thermostat is going in the kitchen
Installing a smart stat in a poor position is a bit like buying a Ferrari and then using it as a golf cart. Putting a thermostat in a sensible position so that it can do its job properly is far more important that having the latest tech IMHO.
The Hive Stat is wireless so can be located in the most suitable location easily. So, here's the low down on the best stat location:
1. The room thermostat should be in a room that is not effected by other sources of heat such as an open fire, cooking equipment, or direct sunlight etc. It should not be somewhere drafty or too close to a window, especially if it's one that is opened in the winter.
2. It should be in a cool room, ideally the last room to warm up. That way the other rooms will be warm enough, (but not overheated if fitted with TRV’s) before the room thermostat switches the entire heating system off. [To achieve this, sometimes it may involve downsizing a radiator in the room where the room stat is located]
3. The radiator in the room with the thermostat installed should not have a TRV fitted. Otherwise the TRV could interfere with the operation of the room thermostat and prevent it from working properly.
4. The thermostat should be mounted about 1.5 metres from the floor, and not close to, or above a radiator.
5. Preferably it should not be on an outside wall, (although if the property has well insulated walls, this is not quite so crucial.)
6. It should be in an area where air can circulate easily, not in a corner, or hidden behind curtains, or furniture.
