As you say - as you expected. However, what they say is obviously only correct if the neon is wired (I would say 'incorrectly') to the switch output - rather than to the output of the whole accessory.OK, response from the manufacturer is pretty much as guessed - it's to do with illuminated switches.The fuse is placed before the switch on all of our fused switches. The reason being, if the fuse blows on any switch with a neon indicator this will extinguish in this set up. If the fuse is after the switch it will still illuminate causing confusion.
Kind Regards, John
