The hob fuse began tripping , one of the rings lost power and now the hob seems to be broken all together. This all happened immediately after I had installed a light fitting, converting a loop rose system with choc blocks. The lights work fine and I can't see how the two are related as they are seperate circuits. My guess is that the hob just started malfunctioning around the same time. Hopefully just a coincidence. Should I just purchase and replace hob or do you feel it is necessary to get an electrician in to take a look.
Any advice would be helpful.
