- Joined
- 6 Nov 2023
- Messages
- 3,632
- Reaction score
- 1,085
- Country
For the one(s) mentioned by securespark, do you not think it’s justifiable to have an isolator, therof?There isn't.
I did read what you wrote so yes, the regs don’t require a local isolator for a cooker/hob circuit.Please actually read what I actually write.
I fail to see how waiting for someone to lie addresses the question I asked the the inquiry stands independently of any falsehoods, and remains perfectly valid whether or not any deception occurs.Please actually read what I actually write.
If you want different answers then you will have to wait until someone lies to you.
Is it just because I asked "do you not think it’s…" doesn’t mean I didn’t read what you wrote; I’m merely asking a question, not disagreeing or ignoring your posts.do you not think it’s justifiable to have an isolator, therof?
Earlier editions of the regs required any metal item (eg metal window frames, bannister rails, etc) to be earthed.But setting the regs aside for a minute, what you haven’t addressed is why older editions did mandate a nearby switch
Are/was there any reasonable grounds for that, and is it not better compared to the isolators?Earlier editions of the regs required any metal item (eg metal window frames, bannister rails, etc) to be earthed.
Certainly haven't and certain won't.I guess you aren’t doing that any more?
No.Are/was there any reasonable grounds for that, and is it not better compared to the isolators?
No.But was there actually a clear unequivocal regulation which required bonding of metal window frames, banister rails, etc to be earthed?
What about the rest of the time when metal parts are earthed unnecessarily introducing hazards.What about a trapped lawn mower flex coming in contact with the metal window frame, as they are usually in close proximity?
Were they?The regulations concerning isolators were clear, but were they clear for the one that you've mentioned?
Never was a valid reason. It is a myth that the regulations required it.Certainly haven't and certain won't.
As you have mentioned this now, why would there be a valid reason to?
Pre RCD requirement days and post RCD requirements days?
Taylortwocities’ reply was clearly attempting to show a contrast between having regulations regarding isolators, for whatever device that may supply, with having regulations concerning with earthing window sills, barrister rails, etc.No.
It made things more hazardous.
Yes, and it was never mentioned explicitly either, so I really don’t know why Taylortwocities bothered coming up with that statement, or even worser, analogy.No.
It was because people misread the regulations which were the same as they are today.
But, the one’s which are guided by the regulations ensuring an earth conductor is run to whatever thing it is, are they really earthed unnecessarily?What about the rest of the time when metal parts are earthed unnecessarily introducing hazards.
Why wouldn’t they require isolators, and why wouldn’t you think anything written by securespark concerning the regulations about isolators begs the question, “were they”?Were they?
If they were, then why were cookers the only appliances which required isolators?
And again, why did Taylortwocities bring this up when it had no correlation to isolators whatsoever?Never was a valid reason. It is a myth that the regulations required it.
To simply illustrate that there is no point arguing that what was considered "best practice" 50 years ago may not have relevance today.And again, why did Taylortwocities bring this up when it had no correlation to isolators whatsoever?
Please pay attention.But, the one’s which are guided by the regulations ensuring an earth conductor is run to whatever thing it is, are they really earthed unnecessarily?
Right.Parts which are earthed but do not require earthing nor bonding are earthed unnecessarily and introduce a hazard.
Right.Window frames etc. never require earthing.
Which is what I was talking about.But, the one’s which are guided by the regulations ensuring an earth conductor is run to whatever thing it is, are they really earthed unnecessarily?
Good.Right.
Right.
You are not understanding what is written.But, the one’s which are guided by the regulations ensuring an earth conductor is run to whatever thing it is, are they really earthed unnecessarily?
There are no regulations that require an earth conductor is run to whatever thing it is that does not require earthing.Parts which are earthed but do not require earthing nor bonding are earthed unnecessarily and introduce a hazard.
Why wouldn't it have relevance today?To simply illustrate that there is no point arguing that what was considered "best practice" 50 years ago may not have relevance today.
But setting the regs aside for a minute, what you haven’t addressed is why older editions did mandate a nearby switch. If the purpose of having it was:
to provide true double-pole isolation at the appliance,
to avoid relying on the consumer unit (which may be tucked away, locked, or shared between multiple circuits, and especially under emergency circumstances.
to give someone working on the appliance a visible & dedicated means of isolation.
Then have those reasons vanished? Or is it simply that we're now accepting a lesser standard because the regs allow it?
So it’s not really about what’s relevant today, or, you know, what might not make sense now, are we talking about isolators, or the whole thing of earthing anything metal in sight? The latter or the former, there’s really no point arguing about that exclusively, not when the whole thrust of earthing everything metal isn’t even in the regs anymore (but you said it was, anyway). It wasn’t even a regulation back then, but having isolators for ovens, hobs, cookers that was.To simply illustrate that there is no point arguing that what was considered "best practice" 50 years ago may not have relevance today.
How and why?may not have relevance today.
But no one mentioned connecting an earth wire to somewhere that doesn't require earthing.There are no regulations that require an earth conductor is run to whatever thing it is that does not require earthing.
I was curious about what you would have said about this.But, the one’s which are guided by the regulations ensuring an earth conductor is run to whatever thing it is, are they really earthed unnecessarily?
