Ok i can see there are lot of topics posted on hobs and ovens but non specific to my enquiry so i will be as specific as poss.
1 x single oven fan assisted (moulded plug)
1 x Gas hob with moulded plug (for ignition)
1 x Extractor with two core flex, bare wires at end.
Can i wire a double spur from a nearby kitchen circuit double and plug in both aplliances and also wire in extractor to spur socket terminals or am i putting too much on a spur.(effectively three items on a double spur)
Or should each appliance have its own fused socket and can i wire these into the circuit rather than spur each one
Also i want to locate the spur/sockets on the opposite side of a wall near to the appliances so they are out of sight but still easily accessible. They will be within the kitchen area there are no obstructions/doors between the appliances and the connection point.
If i am going through the wall i will need to remove the plugs for the hob and oven so can i simply hard wire them or will i need to replace the plugs
