The end user and the supplier need to sit down and spend a long time discussing life style and how the system will fit into the life style of the end user. Think of how it will cope with the un-expected.
The extreme example of a problem that had to be considered is :-
Without naming names one top of the range bespoke system provide auto follow of music as people moved from room to room. This required people to carry an ID tag with them. It also controlled lights if it detected a tag in a dark room. If two people with diferent music following them went into the same room at the same time the system had to decide whose music choice took preference. Should it be the husband's choice or the wife's choice that was given preference.
I see. I dont think I need it that sophisticated. Just central (but distributed if you see what I mean) over lights and AV (including CCTV) and probably heating as well.
Many people used to put Cat 5 runs into rooms for home networks but I prefer wireless.
Someone suggested flood wiring Cat 5 anyway with a couple of sockets in each room - good idea for telephones maybe??
True, however, if you're having wireless controls, opt for WIFI controls. Saves having to point at an IR reciever etc. The WIFI bases can be hidden in the loft or in cupboards.
