I know the phrase 'home made' brings to mind endless dodgy cudgels. However, in this instance, I use it to describe professionally designed and manufactured one off prototypes, not yet certified to any standard but designed to suit.
I have plans for to make a homemade home automation controller. I know you need to conform to various BS to wire devices permanently into domestic mains. However, it there a way of interfacing into mains control via approved equipment?
for example, a mains relay panel that can switch various T&E circuits from 12v DC inputs (as supplied by homemade equipment).
What difference in situation do you get between equipment on a plug, equipment wired into a fused spur, and equipment wired directly into a ring / radial / spur?
Cheers,
Fubar.
Cheers,
Fubar.
