Honeywell Accenta G4 mini
What a schoolboy error. Just wired it correctly on zone 2 and that worked fine on walk test.
I will redo rest now and wire tamper
Blue and yellow are your Tamper pair
Green and white are your alarm pair
So green and white into your zones 1-8 etc
Blue and yellow need to be wired in series together
Blue and yellow are your alarm pair on the contact
You have no tamper on your contact as other wires cut short.
To series tamper circuit blue from detector 1 onto yellow of detector 2 and blue of detector 2 onto yellow of detector 3 and so on.
Ok, that is what I am doing at moment.
So on door contact can I wire in tamper? If so how?
Twist green and white cores together and connect twisted cores on single brass screw in contact
Now you're doing it as well Handy. You've chopped and changed on your pairing system.
So Littledaz, when you've decided on you're pairing standard, concentrate on the following.
Doing that now, I have wired all green and whites to zones, just changing contacts around then will do tamper circuit
We have a result. Just done walk test, everything fine.
Many thanks to all of you who have pointed me in the right direction.
View attachment 117954 I have checked and I can't see where I have wired incorrectly.
I have taken a picture for the rkp
As soon as a pir senses anything in unset mode internal sounder alarm triggers
Any suggestions really appreciated
Hi Littledaz,
Could I ask how you cleared the tamper fault marked F0? I have the exact same fault on mine. I tried extending the spring on the RKP but that didn't help.
All zones are testing OK and the walk around but I can't clear the TP - F0 alert? Any tips?
Any help would be appreciated!
