Hello,
I've been trying to set up my touch center so that it can control the driveway gate for the younger members of our family without phones.
At the moment I'm trying a DCM, I wanted to set up two O/P entries, one for a timed open, say for 2 minutes to allow egress, and one to hold it open when visitors were expected etc.
I'm using O/Ps from an internal RIO, 1011 and 1012 simply so that they are at the top of the list on the touch center, using links to signal the DCM. The hold open function works as intended, holding the gate open via the relay on the DCM but the link for pulse mode just doesn't seem to work although the only differences in the settings are reflex/pulse. It seems that when you set the touch center to 'trigger' mode it fails to send the signal, setting it to 'toggle' means it will hold the gate (DCM relay) open despite the link mode being set to 'pulse'
I can try getting a RIO and using the O/Ps from that but concerned that I will encounter the same issue.
Anyone have any ideas?
Thanks,
Gordon.
Thanks,
Gordon.
