Hotpoint Fridge Freezer intermittently tripping power
12 Jan 2022
Hi
This is my first time posting. I'm trying to find out the problem with my Hotpoint fridge freezer.
Before Xmas, the power tripped. As time has gone on, we've determined that it's the fridge freezer. It's become more frequent now. When the door is opened (and not every time) the power trips. Other than that, we've not notice any issues with it. Temperature is as it should be, lights aren't flickering, all noises are normal and opening the freezer drawers doesn't trip it.
Sometimes the door can be just opened or it will be open for a little while before tripping the power.
We've pulled it forward, so it's not so close to the wall. We've changed sockets (it's not in an extension) and I've even changed the fuse and we're still having problems.
I'm trying to avoid anything too expensive in resolving this. I'd appreciate any advice, please
1 Dec 2006
Cumbria
Am I correct in thinking that it only happens when you open the fridge door not the freezer door or is it just a fridge with a built in freezer compartment. If the former then try removing the bulb from the lamp as that is usually the only thing that switches when you open the door. If it does then you have a problem with the light circuit. Providing the model number may help others advise
12 Jan 2022
Hi
Thanks for the advice.
I started to look at the lights, but we soon found the problem was something else.
There's an electrical cable running from the top of the fridge into the left hand door (no idea why or what's its for!). On closer inspection we saw that the cable was badly damaged and exposed.
After trying to fix the cable & having no luck, we ended up using insulating tape.
So far, the electricity hasn't tripped and the fridge freezer is still working
Still don't know what the cable into the door was for. Everything appears to be working as it should
