Hotpoint washing machine door leaking - fix myself or try to get fixed via warranty or retailer (bought from AO)?
12 Jul 2016
My 14 months old BIWMHG91485UK_WH Built In Washing Machine, bought from AO.com, is faulty.
I put a 60C Bed and Bathroom wash on last night (which takes approx. 3 hours) to wash some towels.
There was excess suds generated for some reason, which has happened before on this setting, even though I only added 1 capsule as normal and a very small amount of fabric softener.
Water started leaking from the door before I switched it off and drained it.
After this I put a quick 10 mins rinse and spin cycle on in order to allow me to open the door.
Since then a very small amount of water leaks from the bottom of the door. Approx a £1 coin size amount on the same 3 hour cycle.
Is this likely to need a new seal and/or door fitted?
Would AO or Hotpoint likely cover this or would I need to try to fix myself?
What is the grey bit in the top right hand corner that seems to go under the control panel and the door in the first pic..
Between the control panel section and top of the door?
The grey square square on the top right hand corner is the magnetic bit for closing the door i think.
I would go back to AO first. At 14 months old it is still well within warranty and the retailer is your first port of call, so do not buy any parts yourself yet. The leak starting with heavy suds is common, the foam climbs the glass and pushes past the door seal, and the small ongoing drip afterwards usually means the door bellows has a small split or has pulled out of its groove. Check round the seal carefully with a torch, especially at the bottom, and run a hot empty wash with a machine cleaner to shift any residue before they come out.
Are they really strict with warranties, or might offer some grace? I'm just under 14 months.
I think the pressure has bellowed the door as i can feel a gap and almost fitting my pinky in the middle of the bottom part of the door when closed.
Is it maybe a new door that would be needed?
Any idea on cost to repair if not covered by the warranty?
I think the part I was asking about is an optical illusion in your pic. I now think it is a recess in the front panel rather than something stuck to it. I did not mean the decorative door magnet
Time for some more pics. if you get no joy from AO.COM.
If the door is warped then I would get on to Hotpoint. You could also check their site for a recall notice.
Hotpoint used to do an all in price for repairs, no doubt they will tell you if you ask, although a local repairer will probably be cheaper. A new door is typically as below if that is what turns out to be the problem, but I was wondering if it has a similar recess at the bottom of the front cover as it does at the top and that is where you are getting your finger in
