washing machine belt has snapped it was on a cycle at the time and now the inner drum has a lot of resistance is this normal or has the bearings gone. can it be fixed easy or do i need a new machine.
Thanks for that took the lifters out and saw no obstruction but resistance gaveway once i released one of the lifters out took all out and no reisistance cleaned limescale away and seems better but think balance on drum has gone as one of lifter was scratching base.
No coins or wire unlees they feel through water pipe when released but the actual drum is scratching outer base and does make a noise when spun manually.
