How could i seal this gap from my shower??
16 Apr 2007
Lancashire
finally had the bathroom all refitted - nice job apart from quite a few gaps left here and there. nothing that i cant do myself with some sealant.
however, i've had a shower cabin fitted and he's not secured the sides to the outer wall. allow my pics to explain.
now whilst the bottom base is fixed as close to the wall as possible - there is an increasing gap as u move upwards. same with the other side
here u can see the gap at the top much closer
two reasons i'd like this sealed - so no water splashes over the top and also u can see the tiles ending and the plaster behind showing
the frame of the shower is metal and silver (not chrome) so could i some how with some pieceing cover the gap permanently? and with what?
have you paid for the work yet? If not, don't, until it's fixed to your (reasonable) satisfaction
If you've paid someone to fit this get them back to install it properly! I could park my van in that gap.... :shock:
the tray seems level - there's no standing water anywhere. it is most likely the walls as the buildin itself is quite an age and on a slope
Always blame the missus mate :wink:
Most shower profiles will take a certain amount of wonkiness in the wall. 25mm approx. Either the tray or wall or both are on the p**s. This is the installers fault, not the wife's!
so dragging the guy back is one option
could it be clipped at the top to secure it to the wall and then covering with stripping?
It should be fixed to the wall. If its not, its going move over time and ultimately leak.
In my opinion anything else is a bodge.
Whereas I can understand there being a problem since the glass splashback may need to be distorted in order to butt and fix the wallplate to the wall properly, the current installation is no satisfactory and will allow movement which will leak sooner rather than later.
something really isn't right, there is an uneven lip where the base meets the screen so it's not equal on both sides
Could be the camera angle making it look skew, but well spotted. While we're going in for the kill ( :wink: ), I hope that that caulk line at the bottom of the plastic trim surrounding the tray isn't onto a finished floor surface :?
Have you got a spirit level to check whether the walls or the frame is out of vertical. Seems an obvious place to start - also the rim of the tray should be perfectly flat (the tray itself will have an inbuilt "fall", so don't use a level on this)
noo i didn't mean that :P i ment the amount that the screen is sitting over the base on the right hand side of the pic there is a big lip, on the left hand side there is hardly any
I know what you meant - like I said it may be the camera altering the perspective (I think the front edge of the tray is a raised lip which may be giving the effect)
