How do I change this downlight bulb?
22 Dec 2009
Hi
How do I change this type of down light bulb please
Had the clip type in my old house so not familiar
Thank You
That looks like a non-replaceable LED unit.
If so, then you have to replace the complete fitting as you cannot replace the 'bulb'.
How do I remove it for replacement if it’s an integrated unit
And why would anyone design something like that?
You replace the entire fitting...they can make more money designing them that way.
Pull it down gently. There are two sprung levers, so mind your fingers (and the plaster) as you pull it free of the ceiling.
Will it be straightforward to replace this unit (and other matching ones) with ones that have easily replaceable bulbs or are they wired differently?
No, not wired any different and can be replaced with 'normal' ones but be careful to get ones with the similar details.
i.e. if they are 12v, instead of the normal 230/240v then you will need to get a 12v one, (or set if replacing the others.).
Tip: As you start to pull it down slide the fingers of your other hand up to form a ring around the unit. You should feel what feels like two stiff wires running upwards on each side. Keep a firm squeeze on them as the unit comes out to prevent them snapping against your fingers.
