N
Newboy
The first swept T burst due to heat and pressure - it hasn't actually come apart, it's split at it's weakest point. Given that PVC starts to degrade at c.140°C and 'melts' at a not much higher temperature & ABS behaves strangely but softens at c.110°C it doesn't take a lot of chemical reaction between sulphuric acid and whatever is in the waste pipework to risk a pipe rupturing.
I'd only ever use OS or equivalent on external underground clay/cast - if a blockage can't be cleared by mechanical means then the install is cr*p and cut it out and replace.
It definitely shouldn't but I've seen more than one occasion where it has - not pretty!
O.. S... can't be used on urinal pipes that's for sure !!!!!
