u r a genius
i posted and then had the same thought
lol
one problem is that i need a double length width switch
everywhere only sells single width
i asked here before and was given some links for a double dimmer - but the cost of that was £30
- can u suggest anywhere i can get double length switches?
- else... is there a way to remove the dimming part?
- i was thinking of buying single units and then removing the modules and fitting onto the existing plate. is that a bad idea?
i need the knob as well - it's damage on one of the switches
can u tell me where i can buy? i have actually searched for just modules... but couldn't find...
so i thought a better idea would be to simply buy new ones and take out and fit onto existing plate. i'm assuming that the whole will just be a standard width on the plate
but then i still have the problem of removing the dimmer function...
omg... thank u!
i've now also found a seller on ebay who sells the knobs
will cost £3... but ok, i can live with that
i'm replacing modules that are 400w rated
i assume these will be ok?
there is no rating mentioned on these units
thanks
(i've also emailed the website asking they'll be ok - just being ultra safe)
All those switch modules can handle more than any dimmer, so no probe.
The TLC unit comes with a knob. But note they will add VAT to those prices and £4.50 P&P.
