How do I remove this drywall socket backbox without breaking it?
7 Apr 2021
Hello how to I remove this plastic case without breaking it? We need to make a bigger hole to push the wire through so think it’s best to take it out before hand. It’s used to hide the wires so really don’t want to break it so thought I was best asking here. Thank you for any help.
The little slot to the right and left of where the screws go, put a flat blade screwdriver in and gently pry away from the centre of the box and the yellow section will pop out
Before you try and remove it from the wall, run a stanley knife round the edge of the box where it meets the wall. Otherwise you risk yanking off several layers of paint and (possibly) filler.
If you watch this video from about 6:20 you'll see how it all works.
when you prise the yellow tabs inwards you can be quite brutal as they dont break easily
