The existing valve has a male threaded 1/2" BSP tail. This takes the backnut and the pipe connection. More common to see a tap connector screwed straight on, rather than an elbow like yours, but in any case you need to take off everything outside to remove the valve.
When you've got it off, why not dismantle it and replace the rubber washer, and give things a smear of silicone grease? It should be good then for 20-odd years!
Great info and and advice. I have already bought a new replacement float valve Type2. I was under presumption that all these valves would be same fitting design. But obviously they are not. I will take the whole valve off the tank, and replace with the new Type2 float valve.
Thanks.
