- Joined
- 1 Apr 2022
- Messages
- 17
- Reaction score
- 2
- Country
I’m having the usual constant vs timed hot water debate with myself and just need to know how the tank behaves when supplying water. As far as I understand (and I’m probably wrong), if your DHW is timed, the boiler will come on and heat your water to 60C and go off. If you then go and have a shower and use 50% of the water, cold water will immediately refill the tank and the water temperature in the cylinder will drop to somewhere between 60c and the temperature of the introduced cold water, say 35c.
Am I right in assuming that cold water will start filling the tank as you’re using it? If this is the case, won’t the temperature of the water in the tank drop rapidly as you’re having a shower?
This doesn’t seem to happen with our system at home. The temperature does drop but only quite slowly as you’re showering.
Is there a stopcock-type arrangement (like in a cistern) in the tank where water has to go below a certain level to start filling again?
Sorry for the noob questions, just trying to learn!
