Just about to screw a nice bit of planed 2"x2" to the wall which is going to be a visible top edge for hiding a gas pipe. However, I've noticed my wall is not straight!!!
The timber is 7'6" long and 2"x2" size, and when I put the timber against the wall I see that its about 1/2" away from the wall in the middle. I can push it about 1/4" closer with my bear hands, so I believe a few good screws will force it against the wall. The wall behind is an exterior cavity wall constructed in the '80s so likely to be breeze blocks and plaster internally.
Should I file the ends of the 2"x2" to reduce the degree of bend required, or can I just force it to bend with some strong screws? If so, what size screws and rawl plugs would be recommended?
