I wish to fit a washing machine supplied via an 20A isolating switch above the work surface feeding a 13A socket below work surface into which the washing machine will plug. The isolating switch will be fed as a spur from a 32A junction box broken into a below floorboards kitchen ring. This is all perfectly OK I believe but is it permissible to run a second spur from the same junction box to feed an 13A switched fcu also fitted above the work surface which I intend be a boiler supply point. All the wiring in 2.5mm t & e buried in tubes in the wall.
This would mean four cables connected into the junction box - ring (2x) and spurs (2x).
The junction box I bought confusing had 2x 2.5mm written on its underside which is when i started wondering about all this.
Thanks for any replies.
