How many wires can be fed into a block connector?
9 Aug 2005
I have a single unswitched wall socket. It has 3 live wires, 3 neutral and 3 earth. I presume that this socket is supplying a spur nearby?
I have attached a double socket conversion plate kit. My problem is that I am having difficulty rewiring the double socket (the replacement) due to the wires not reaching, eg: the earth is on the opposite side of the double and I am struggling to get all 3 live wires back into my new double socket.
Is the solution to feed the 3 lives, 3 neutrals and earths each into their own block connector eg: 3 lives going into 1 block conector and then feeding a a single wire out of the block connector and into my new double socket? I say this as it would be stupid to use a total of 9 block connectors! Is this not sensible?
yeah existing wires into the block connector and then a single wire to each terminal of the socket will be fine.
what kind of conversion is this? is it a traditional big one with a seperate socket and converter box (in which case you'll have no problem finding room for the connector block) or one of those thinner one peice ones (in which case you may well have space problems).
