    Dismiss Notice
How to wire ceiling light
Discussion in 'Electrics UK' started by angularbanjo, 8 Oct 2011.
  1. angularbanjo
    angularbanjo
    3 Mar 2010
    30
    Thanks Received:
    Perthshire
    Country:
    Hi
    From the roof I have 3 wires:
    Red (live)
    Black (Neutral)
    Yellow/Green (Earth)
    My new light fitting has a 4-way connection block
    Connector 1 has earth (yellow/green)
    Then there are 2 white cables each with one live (brown) and one blue (neutral) wire coming out of them
    Connector 2 has one of the live (brown) wires
    Connector 3 has both of the 2 neutral (blue) wires
    Connector 4 is empty but the remaining live (brown) wire looks like it's just came loose from there
    So... I have 3 wires from the roof and a 4 way connector block, could someone advise how I connect this up please?
    Steve
  2. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,189
    Thanks Received:
    2,085
    Oxfordshire
    Country:
    Sounds like the loose brown wire should be in 2.
    4 will be there as a spare for a 'loop in' wiring scheme - you do not have that.
    The your earth goes to 1
    red goes to 2
    black to 3
    If you not sure, post a picture of the light and we'll have a look.
    Or take it back to the shop and get another one.
    PS. Didn't it come with wiring instructions?
  3. Sponsored Links
  4. angularbanjo
    angularbanjo
    3 Mar 2010
    30
    Thanks Received:
    Perthshire
    Country:
    Thanks, that makes sense
    Both neutrals in the one connector and both lives in one connector then just join them up like to like...perfect!
  5. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    Sounds like your new fitting has two lamps connected to it so as Taylortwocities has suggested.
    Connection terminal 1 earth cpc of fitting to earth/cpc of circuit
    Two browns in connection terminal 2 connected to red of circuit
    Two blues in connection terminal 3 connected to black of circuit
    Connection terminal 4 is a spare used as loop in live, which you don't need!
  6. Sponsored Links
  7. angularbanjo
    angularbanjo
    3 Mar 2010
    30
    Thanks Received:
    Perthshire
    Country:
    yes, you're right it does have 2 lamps, I know just what to do now, many thanks
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
