You should be using a thick bed solid bed trowel, this is the type with half round notches, if the stone is well calibrated that should be OK if not you will need to go upto a large format trowel same design bigger cutouts.
Assuming 20kg bags expect about 3 sq mts coverage with the thick bed solid bed trowel and 2 sq mts with the large format and don't forget to use white adhesive as the grey may soak into the tile and show through!!
10 kg bag of widejoint superflex grout should do all the floor
it's only about half the tiles being used for the floor, the rest is for the wall, would it be better to get normal, non flexible adhesive and grout for this (cheaper?)
Stick with the same grout for colour match and one 10kg bag will cost less than 3 or 4 3.5kg bags.
What thickness is the stone, you should be using 12mm for the floor and 10 or less for the walls as the weight may be too much. A skimmed wall will only hold 20kg/m2 tile and adhesive, 32kg for bare plasterboard and 50kg for aquapanel.
