Because 4mm² is the minimum size for an unprotected earth cable.
You are probably right but I cant find this in BS7671? Have you a page number?
I knew that already... What I asked was What is the actual physical diffrence
Class 1 will have an earth terminal class 2 do not have an earth terminal.
A lot of non-NICEIC contractors believe they have their own set of regs, indeed many in the 'club' think this too, because their work is criticised. But, the NICEIC inspecting engineers always assess work to BS 7671. They may suggest a method of achieving compliance that a contractor thinks is OTT, but invariably that is because the contractor has, often for years, used a non-compliant solution, or an outdated one.
Thats a bit obvious but how is the wiring different ( thicker insulation - more of it ?? )
The basic requirement is that no single failure can result in dangerous voltage becoming exposed so that it might cause an electric shock and that this is achieved without relying on an earthed metal casing. This is usually achieved at least in part by having two layers of insulating material surrounding live parts or by using reinforced insulation.
So would you agree that NIC inspectors would insist on something like an earth fly-lead to a metal back box, even though the (apparent) consensus on here is that BS7671 requires only a screw/fixed lug?
No - it has to be designed into the product - there's nothing you can do to a Class I luminaire to turn it into a Class II one and still get light out of it.The blurb just mentions "extra insulation" .... Could this not be retro fitted?
TBH Dingbat, until the regs are clear cut (never) there will always be differences in opinions and incorrect departures noted on PIR's, it is a book full of 'shoulds' ! There are some members in here that truely believe that the regulation instigating the provision for a main switch, ie single point of isolation for an entire installation, is infact a regulation for shower oull cords to be sighted inside bathrooms!
