- Joined
- 11 Jan 2004
- Messages
- 46,023
- Reaction score
- 3,570
- Country
Proposed floor insulation and plaster boarding and plastering
Room size 5.7 metres long x 3 metres wide
Includes confirmation survey
Take up the existing floor boards,remove from site and replace with new suitable mould resistant tongue and groove 22mm boards
Take down existing en suite partition wall and timbers etc and remove from site
Fully insulate the floor in between the joist with 100mm or if not possible 75mm celotex or similar heat saving rigid insulation boards
Seal any gaps in the corners
Re build the en-suite stud wall If new door and frame required this would be extra depending on door and Furniture etc
Supply and fit insulated plasterboard 25mm insulation plus 12.5mm plasterboard total depth 37mm (standard plasterboard would be £215 less )
Re plaster all walls and ceiling and also around the reveals of the windows were necessary
Supply and fit new skirting boards all round
Supply and fit new coving all round
Large skip included
All the work carried out by skilled joiners and plasterers and we would envisage it to take around 12/14 days in total with a minimum of 2 men per day on site
fully Project managed
Also, they mention insulation-backed PB....is there any need with a warm roof above?
Will the use of IPB a) do nothing or b) make the room warmer or c) create condensation?
Thanks, guys.
Thanks, guys.
