- Joined
- 3 Sep 2025
- Messages
- 1
- Reaction score
- 0
- Country
Hi all
Am new here so please go easy. We had an alarm fitted a few years ago but the engineer has since died. Before he died he did give me the engineer code for the alarm.
The alarm we have is a Pyronix Enforcer, where all the shocks and contacts are wireless. So, recently, we took down our old conservatory. Before we took it down I removed the sensor and the 'other piece' and sellotaped them to each other. I then put the sensor etc in the Kitchen drawer. However, since then, the system knows that there's a 'problem' with that zone and asks us to set without that zone 'Conservatory door'. I want to know how to completely omit that zone. Any advice please?
When I go into the engineer menu, I log on with the engineer code and scroll down the following options:
SET DATE & TIME
WIRELSS DEVICE CONTROL
CHANGE INOUTS
CHOOSE MODE
INSTALL ZEMS
CHANGE OUTPUTS
ASSIGN KEYPADS/READERS
CHANGE TIMERS
CODES AND USERS
VOLUME CONTROL
SYSTEM OPTIONS
REVIEW LOGS
ENGINEER TESTS
DIAGNOSTICS
ENGINEER RESTORE OPTIONS
COMMUNICATIONS
ALARM RESPONSE
SET UP DOWNLOADING
DIAL OUT MENU
SOFTWARE REVISION V10.25i
4301E583Enforcer
SOFTWARE REVISION
CLEAN START
EXIT ENGINEER MENU
Basically, all I want to do is take away that zone, so I don't keep getting harassed with the message (similar to) Set without Zones/errors.
SET DATE & TIME
CHANGE INOUTS
CHOOSE MODE
INSTALL ZEMS
CHANGE OUTPUTS
CHANGE TIMERS
CODES AND USERS
VOLUME CONTROL
SYSTEM OPTIONS
REVIEW LOGS
ENGINEER TESTS
DIAGNOSTICS
COMMUNICATIONS
ALARM RESPONSE
SET UP DOWNLOADING
DIAL OUT MENU
4301E583Enforcer
SOFTWARE REVISION
CLEAN START
EXIT ENGINEER MENU
