Anyone see it ?
Indeed. In fact, it would almost be correct if one more-or-less reversed it by replacing the words "anything other than the earth wire" with "a connection to earth"!"An RCD is a switch designed to trip when the electricity is flowing out of the house through anything other than the earth wire"For anyone who doesn't know that's completely wrong.
Well, I only said 'almost correct', but ...Oooh. I don't think that is really correct.
What return paths back to the tranny, "other than the neutral wire", were you contemplating which would not be covered by my "a connection to earth"?Surely it would only be totally correct to have said "anything other than the neutral wire".
Did it say what else they were touching?On a positive note they mentioned someone had died when they got into the bath and touched the taps.
Ah. I misunderstood your intention. Sorry.The point I was trying to make was that they 'almost' got it totally back-to-front!
Yes, they said "anything other than the earth wire", whereas I was suggesting that "anything, so long as it is a connection to earth" would be much closer to the truth!Ah. I misunderstood your intention. Sorry.The point I was trying to make was that they 'almost' got it totally back-to-front!
An 'unnecessarily' earthed/'bonded' bath, perhaps?No they didn't
But it has to flow out of the house, right? The RCD won't do anything if it's only flowing in the house? That's what they mean, right?Indeed. In fact, it would almost be correct if one more-or-less reversed it by replacing the words "anything other than the earth wire" with "a connection to earth"!"An RCD is a switch designed to trip when the electricity is flowing out of the house through anything other than the earth wire"For anyone who doesn't know that's completely wrong.
Maybe, and I'm not disagreeing with any of that ... it was only words after the ones about 'flowing out if the house' which I was suggesting could/should be changed to make it much closer to being true!But it has to flow out of the house, right? The RCD won't do anything if it's only flowing in the house? That's what they mean, right?Indeed. In fact, it would almost be correct if one more-or-less reversed it by replacing the words "anything other than the earth wire" with "a connection to earth"!"An RCD is a switch designed to trip when the electricity is flowing out of the house through anything other than the earth wire"For anyone who doesn't know that's completely wrong.
There was a faulty electrical appliance, however the cable to the outdoor earth rod had corroded.
