how to build a new stud wall for bathroom and doorway ???
24 Dec 2005
Cheshire
hi im after building a new stud wall upstairs in a house im getting as at the moment it has a seperate toilet and loo-so what im looking at doing is nocking through existing wall from toilet to bathroom and making 1 big room.
are the uprights of the new studwork best fixed to a piece of batten attatched to the floorboards or is it best to get floorboards up and attatch to original floor joists and the same with the ceiling-is it best attatching 4x2 across existing plaster ceiling or nocking through plasterwork and attatching to joists again....
whats best timber to use for this 3x2 or 4x2.
should uprights be 400mm centres.
use normal 12mm plasterboard or rubberbacked noise stuff for where it meets landing???
is it worth use noiseboard to eliminate
whats the best method to fit new doorframe to this structure....
thanx
are the uprights of the new studwork best fixed to a piece of batten attatched to the floorboards or is it best to get floorboards up and attatch to original floor joists and the same with the ceiling-is it best attatching 4x2 across existing plaster ceiling or nocking through plasterwork and attatching to joists again....You can fit straight thru existing but check for pipes and wiring and think about if you will need any power in this wall? as cable needs to be accessed before it goes up.
whats best timber to use for this -- 4x2. better suited to adding a door frame
should uprights be 400mm centres.--Yes
use normal 12mm plasterboard or rubberbacked noise stuff for where it meets landing??? Normal stuff with insulation
is it worth use noiseboard to eliminate No
whats the best method to fit new doorframe to this structure....Buy door and frame first then you can leave the correct gap to fit to uprights.
thanx
