We bought enough reclaimed pine floorboards to cover the bottom floor of our (open plan) house. When choosing a product to seal it, we were recommended Osmo hardwax oil by the supplier.
We want a light-coloured look that is as close to the original pine as possible. We also want to keep the character of the reclaimed wood surface as intact as possible - it's been lightly wire-brushed by machine but still has plenty of colour variation, holes, knots and bumps. These make us happy.
What we don't want is an orange surface (a 'sauna' look).
We tried a few tester pots of Osma on some samples of the pine and the 'raw' version seemed ideal. The white pigment counteracted the natural tendency of the oil to give the wood a 'wet' look.
Unfortunately, after the builder applied a coat to half of the floor, we saw problems. Some planks (especially the darker ones) really picked out the white, looking like they'd been badly painted. Some with rougher surfaces picked out the grain in white, which looked quite ugly. Some looked OK, but all of them looked incredibly cold in sunlight. Almost like they were glowing a very light blue. (Is Osmo Raw UV reactive?)
So we asked the builder to stop staining while we re-evaluated. Also we asked him to experiment with sanding and wire-brushing to see how much could be undone.
With some light to medium sanding (using a hand sander) followed by wire-brushing along the grains we can bring things back to something acceptable - dark boards become lighter, the white is tamed (but not eliminated) and a lot of the coldness is removed. Some character is lost, but at this point it's probably an acceptable loss. The brushing exposes the grains a little as well, which we like.
SO:
- Is there a better way to remove the Osmo Raw tint?
- Is there a way to get a natural, non-orange pine look without Osmo Raw?
- Considering half the floor is now tinted (tainted?) with Osmo Raw, how can we get a consistent finish across the whole surface?
I'm guessing the answer to 3 is: 'wax the rest of the floor and sand back in the same way'...
We have spare boards we can use to test different combinations and scenarios if needed. This time we want to get it right - any help would be very much appreciated.
The wood is glued in place and the surface (as you can imagine) is not even.
Thanks!
SO:
Thanks!
