Hi Guys,
As explained in a previous post, I have stripped all the plaster off of a number of walls in the house. This is right down to the brickwork, which being a 1930's house is rather rough, i.e. not a smooth block like surface.
I plan to attach plasterboard to the walls using dot+dab, but have heard conflicting advise on how to apply the board adhesive. Some advise (including all of the youtube videos I've seen) show the adhesive being applied very sparsely. Around the edges and and a few areas in the middle.
Other advise suggests applying the adhesive to the back of the board rather than to the brickwork, but close enough blobs so that when it's pushed to the walls, the adhesive will join together making a continuous bonding surface.
The latter will obviously require a lot more adhesive. The other advantage I can think of the second method is that the board would not feel hollow like drywall.
Any advise?
Any advise?
